Retcol: Wheel type changed near the end of M production. Before that all H or M rims were drop center, thus the center casting was smaller, clamps or lugs are different from the newer type. I expect those older rims and lugs were made by IH.
Beginning at SH-SM time all Farmall larger than the Super C were equipped with double bead rims and the center cast changed, bit larger diameter.
I've seen different clamps or lugs for the double bead rim type, and yes the outside supplier was the factor that made them different. Once manufacturers went to double bead rims the rims and lugs became standardized. I've used both Cockshutt and Deere rims on later Farmalls. The different outside suppliers is the reason for some differences, however the lugs for double bead rims will all interchange. You can even use a mix of several different types of lugs I've seen.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
