Re: hydraulic for an farmall h
Posted by Scott Rukke on February 22, 2008 at 12:25:33 from (67.183.230.71):
In Reply to: hydraulic for an farmall h posted by Larry Caldwell on February 22, 2008 at 10:17:10:
third party image
Here is a schematic for how to plumb the lines. This will give you power up and down. Although you can plumb the return into the filler neck it is best to plumb it into the drain by installing a tee and plugging one side. This way you won't get as much foaming of the oil. And you can use 30w motor oil.
