Re: Okay, last question. Which way to the seals go?
Posted by Owen Aaland on February 22, 2008 at 12:59:34 from (65.161.86.122):
In Reply to: Okay, last question. Which way to the seals go? posted by mhalter on February 22, 2008 at 09:48:07:
You are correct. The spring side of the seal faces the oil you are trying to seal. In this case you need to seal both the engine oil and the diesel fuel so the seals need to be installed one facing forward and one facing the rear.
