Re: ??'s for hugh mackay..
Posted by Jim Becker on February 22, 2008 at 15:45:15 from (71.170.14.36):
In Reply to: ??'s for hugh mackay.. posted by glennster on February 22, 2008 at 10:51:04:
The one in Bob M's picture is a home brew and more extreme than the factory version. The factory version was actually a high wide option. The rear tires were changed out for ones on a 30" rim. The rim had long lugs to bolt to the original wheel centers. The front tires/wheels were changed out for 15" versions.
A 5" extension was bolted to each rear axle to add a total of 10 inches to the track. The center secton of the front axle and the tie rods were lengthened to match the rear.
