Re: 656 Hydraulic Pressure Check
Posted by Allan In NE on February 23, 2008 at 10:44:42 from (148.78.243.24):
In Reply to: 656 Hydraulic Pressure Check posted by JerryF on February 23, 2008 at 09:42:44:
Jer,
Not trying to be a smart-mouth, but you replaced the right pump, didn't you? The front one?
How about that balance valve down there at your right boot heel. That isn't stuck or leaking across to the other side is it?
Sure sounds like it's going into full system pressure then losing it at a massive leak somewhere.
Does the hitch work normal in and of itself?
Allan
