Re: CRANK SAFETY
Posted by steelfronts on February 23, 2008 at 11:55:06 from (24.236.223.115):
In Reply to: Re: CRANK SAFETY posted by Janicholson on February 23, 2008 at 07:20:37:
Jim
Just to explain. The W40 is a hard to crank tractor.The strokes are only 60 degrees apart so TDC doesnt happen at the top and bottom of the crank stroke. Even if you just pulled up like normal and it kicks back you are only at ten oclock.There isnt enough time to get out of the way and if you hang on it'll shorten your spine.The only good answer is to have timing and impulse working properly and having it start in one or two times around and be younger than say 25 or so
