Re: 404 Utility - Couple Questions
Posted by TractormanNC on February 23, 2008 at 17:06:58 from (209.42.180.19):
In Reply to: 404 Utility - Couple Questions posted by Mike In NY on February 23, 2008 at 09:29:19:
Just went thru this with a 504G. think it is the same starter. there is a flat washer that will come off when you take the drive end housing off. The next washer is held by a "captive" wire ring. Take a 1/2 in drive 9/16 12 point socket and put the 9/16 end over the end of the shaft and whack lightly with a hammer. The wire ring will "usually" stay in the shaft groove but be ready to catch it if it flies off. HTH
