Re: M firing on only 3 cylinders, suggestions?
Posted by old on February 23, 2008 at 17:28:56 from (4.244.186.166):
In Reply to: Re: M firing on only 3 cylinders, suggestions? posted by unioncreek on February 23, 2008 at 17:22:43:
I would replace the cap and rotor and see what happens. You could have a small crack in that area of the cap and a meter might not see the high voltage leak it would have if it has a crack
