Posted by CNKS on February 23, 2008 at 19:28:51 from (216.144.104.128):
In Reply to: tractor won't run posted by Farmboy835 on February 23, 2008 at 19:11:45:
Timing. Set #1 to TDC, then turn the flywheel by hand (screwdriver or have someone turn the crank) until the marks line up. Remove the distributer and set the rotor so that it lines up to #1 in the cap. Reinstall and rotate counterclockwise. remove wire from coil, hold 1/4 inch from screw on dist and rotate distributer clockwise until it sparks. Provided you have good points, coil, and condensor, regardless of what you did, if it does not start, you then have a fuel problem.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
