Posted by Scott Rukke on February 23, 2008 at 20:02:15 from (67.183.230.71):
In Reply to: yeah but posted by Farmallb on February 23, 2008 at 19:16:49:
I think finding a running F-20 engine will be tough. You can find running F-20's for between 500 and 1000. Can't imagine why someone would take a running engine out of one. Everything else seems to last longer than the engines. As for an overhaul kit, not sure what you saw for $300. I just went through my 38 and could find no available kits for the F-20. I spent $85 on rings, $90 on a full gasket kit, 175 for a valve job and then honed the cylinders and put her all back together. These engines are tough, real tough. They're designed to be worked on in the field. You can actually remove a piston in the field through the access holes. The sleeves are even tapered on the bottom so you don't need a ring compressor.
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w
... [Read Article]
Latest Ad:
[More Ads]
