Re: 656 Hydraulic Pressure Check
Posted by JerryF on February 24, 2008 at 08:19:14 from (75.88.95.249):
In Reply to: Re: 656 Hydraulic Pressure Check posted by TX656 on February 24, 2008 at 01:00:32:
The piston is located inside the cylinder. The way I checked it (not saying it's the proper way) is I retracted the cylinder all the way, then unhooked the lines on the bottom of the cylinder. Tried to retract some more and the side with bad piston seals had oil pouring out. The good side may leak a little, but just a couple ounces and then quit. Koyker has a good website and links to owners manuals on how repair the piston seals. Now just have to wait until Monday when the dealer opens to get them.
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and ... [Read Article]
