Posted by ihc49er#2 on February 24, 2008 at 08:36:03 from (216.123.197.130):
In Reply to: tractor won't run posted by Farmboy835 on February 23, 2008 at 19:11:45:
you didnt say if you had camshaft out, sounds as if timing marks are not in line. i would remove valve cover and turn engine over slowly and watch what valves are doing when #1 is coming on comp. in.& ex. should be closed.its running mate #4 should be on the rock.that is with timing marks on front pulley lined up then rock pulley back and forth about 2"and #4 valves should be rocking also.this is the way to set valve clearances, just watch when the running mate to the cyl.your adj.is on the rock.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
