Posted by Hugh MacKay on February 24, 2008 at 14:31:13 from (209.226.247.35):
In Reply to: Farmall C - Super C posted by Ronn Boehlke on February 24, 2008 at 09:33:32:
Ronn: Go to the casting date codes, although a SC with that low serial number could have some codes very close to the last C. Thet might not tell you.
Check the engine serial number, just below number 1 spark plug, on a machined flat surface. Letters and numbers are stamped. A Super C with tractor serial number 113313 should have an engine serial number around 13800.
Then go to the block part number C will be 251069 R1 or R2. SC will be 354898 R1. Super C fuel tank is about 2.5" above hydraulics, while C is fuel tank is about 1/2" above hydraulics. Then there are the brakes and pedals someone else mentioned. Don't go by the water pump, there have been more of those added to Cs than a dog has fleas.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
