Posted by Jim Becker on February 24, 2008 at 19:41:47 from (71.170.14.36):
In Reply to: magneto removal from W4 posted by Canadian Ken on February 24, 2008 at 18:42:23:
The easy way to remove and replace:
1. Hand crank the engine until you hear the impulse coupling click.
2. Scratch a small witness mark across the mag mounting flange to the engine block.
3. Take the distributor cap off and note which way the rotor is pointing.
4. Unbolt the mag and go do whatever needs to be done to it. DO NOT TOUCH THE ENGINE WHILE THE MAG IS OFF. LEAVE IT WHERE IT SITS.
5. When ready to remont the mag, turn it backwards until the rotor is pointing where it was at step 3.
6. Bolt the mag back in place and line up the witness mark.
7. Rotate the engine to verify the impulse clicks at TDC. It is unlikely that you will need to do any adjusting.
If you don't want to add scratch the witness mark, the impressions in the old gasket will probably be good enough. Without either, you just need to adjust the timing per the manual.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
