Re: tractor won't run
Posted by Patrick Martin on February 25, 2008 at 20:14:11 from (64.154.26.250):
In Reply to: tractor won't run posted by Farmboy835 on February 23, 2008 at 19:11:45:
OOH!
Something comes to mind here with something I did with the wiring.
I somehow wired the darn thing to where I was getting no spark when I put a load on the starter or vice versa.
Have someone check the fire as you turn it over and check to see if the coil stays energized when you let go of the switch.
