Posted by Bigdog on February 26, 2008 at 06:47:30 from (65.24.121.84):
In Reply to: Re: Cub Clutch posted by scott 1957lboy on February 26, 2008 at 06:31:27:
WD 40 will do nothing for the pilot bushing and you can't get to it through the hand hole anyway. The only way to get to it is to split the tractor. If you haven't done so already, grease the throwout bearing too.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
