Re: Still no spark on #3 cylinder?
Posted by Janicholson on February 26, 2008 at 13:37:22 from (199.17.6.122):
In Reply to: Re: Still no spark on #3 cylinder? posted by unioncreek on February 26, 2008 at 13:31:58:
If you pull that same number three plug, that may be shorted (see the post above) and a different plug will show spark. TUrn the cam around so the rotor is pointing to #3 (should be down and left at 8:00 o'clock or so) and see if the points are opening. turn it a bit farther and put a screw driver against them while open and see if it sparks then. Get back to us, JimN
