Posted by 495man on February 26, 2008 at 14:08:34 from (24.222.9.184):
In Reply to: IH 464 rev gearing posted by Hugh MacKay on February 26, 2008 at 04:50:36:
driven newer variations of same tractor rear end /trans
All 4 reverse gears should be the same or similar speeds to the 4 forward low range gears. I think 4-5 MPH was the top speed in reverse.
The hydraulic shuttle on the later variations (i.e. 685 etc ) gave you faster reverse gears and reverse in high range....
How fast in 1st gear reverse? Should be under 2 MPH? I can see that being a hurdle for snow blower work in heavy wet snow. Snowblowing is the only full PTO rpm slow speed reverse work I can think of off hand.
Smaller rear tires might help, especially if someone installed way oversized tires, 14.9-28 or 13.6-28 would be about normal.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
