Re: Still no spark on #3 cylinder?
Posted by El Toro on February 26, 2008 at 16:21:37 from (205.188.116.73):
In Reply to: Re: Still no spark on #3 cylinder? posted by unioncreek on February 26, 2008 at 13:31:58:
You need to take look at the cam lobe in your distributor to make sure it isn't worn. Bring No3 piston to TDC on the compression stroke and see if there's any point gap. Do what someone else mentioned is to snap those points open and close while someone watches the plug to see if it fires. You need the ignition switch on too. Hal
