Re: Still no spark on #3 cylinder?
Posted by HAS on February 26, 2008 at 16:59:27 from (209.124.248.162):
In Reply to: Still no spark on #3 cylinder? posted by unioncreek on February 26, 2008 at 12:57:55:
DO this test: With the ignition off and the cap removed, hook an ohmeter from the primary on the points to ground. Slowly rotate the engine two full revolutions and watch the ohmeter as each lobe opens the points. The ohmeter should go to zero (infinity) as each lobe opens the points. If it does not, the cylinder affected by that lobe will not fire.
Do this with all the plugs out so the engine will be easy to turn.
