Using a timing light is not a good way to check for spark. A good way is since it runs on the other cyls, pull the plug boot back on the problem cyl, fire up the engine, and carefully remove the wire from the plug and hold it a small distance from the head or block. See if it jumps a spark and report back to us on long of a gap it has when it can't jump any further. If it will jump good this way then it is time to look at the plug, then the cyl. Also if it will jump a spark this way, switch the plug with one from a good cyl.
It is possible the bushings in the distributor are worn enough that the points won't open enough on the one cyl. Seen this a few times on cars. If this is the case I would guess the plug wire for the problem cyl is on the same side the points are on. The constant side pressure of the points spring can wear the bushings
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
