Re: Still no spark on #3 cylinder?
Posted by Brownie450 on February 26, 2008 at 18:40:07 from (216.51.158.220):
In Reply to: Still no spark on #3 cylinder? posted by unioncreek on February 26, 2008 at 12:57:55:
I forget if you have checked for continuity through the dist. cap with an ohmmeter. This would show up the possibility of no contact on the #3 terminal--even though you have changed dist. caps. Chances of getting a grounded {shorted] spark plug put in #3 as many times as you have had it in & out is probably not the problem. I'd start the engine & pull out the #3 wire from the dist. cap & put a bare wire in #3 & feel if you have a spark. If you hold on tightly, it won't bit too much.
