Re: Super a carb problem
Posted by riverbend on February 26, 2008 at 19:39:05 from (208.160.34.147):
In Reply to: Super a carb problem posted by lacash on February 26, 2008 at 16:44:40:
Un-stabilized (or un-seafoamed) gas goes bad in just a few months, all the volatile stuff evaporates. Use fresh regular unleaded gas.
If the fuel was not shut off when it was parked, clean out the carb. Put in a set of plugs, and points. Re-set the timing.
Fuel dripping out of the bottom of the carb is normal if you crank it very long with the choke closed.
When you try to start it, leave the ignition off, close the choke and crank it two or three times. Open the choke, turn on the ignition, and open the throttle 6-7 clicks (~1/4 throttle), and then try the starter again.
Good luck.
Greg
