Posted by SheldonS on February 26, 2008 at 21:54:51 from (76.196.76.43):
In Reply to: Farmall MD posted by JFavor on February 26, 2008 at 16:53:05:
ihc49er#2 said: (quoted from post at 21:54:53 02/26/08) another thing is they will fire right up directly on diesel when you stop them and restart it. and no you dont switch to gas once its cooled off just shut it down.many people think you should run on gas before shut down because it cleans the carbon out of the plugs.simply not true,there is never any diesel combustion at the plugs. if you dont believe it then remove them while your idling on diesel. if those tiny gas valves are doing there job you will have 0 compression leakage .
I copied the page a few weeks back from an original TD-6 owners manual (same D-248 engine as the MD) that states to switch back to gasoline when shutting it down for ease of starting next time.
What you do have to make darn sure of if you do, is that you seat the valves back down to prevent warping (pushing the compression release valve back forward again). This is stated right in the original owners manual as well.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
