I ran a Vermeer round baler of about the same size last year with that tractor. You have to set up the hydraulics to run a two way cylinder but other than that it will work.
The IPTO makes it easier when you're finishing a bale because you can stop the tractor but keep the bale rolling while you tie it up. Without it you have to either do some fancy footwork or pull off the windrow. The round baler is simpler in function than a square baler, IMO. You just have to use common sense when making a bale in one with a smaller tractor. You might have to make a little bit smaller bale. It takes more HP, as the bales get bigger and heavier, to keep rolling the bale in the machine. A round bale could be anywhere from 800 to 2000 pounds depending on the size of the machine and how tightly it rolls the hay.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
