Like Nawlens suggests you'll need close to 25 HP into the generator to get the ~11 KW of electric back out of it. And the H engine is rated at 24 HP if I recall - so it should work except possibly when the genny is loaded to ITS maximum output.
A few considerations:
1 - If you're gonna direct drive the genny it'll need to be a 4 pole gen head and the engine will have to run at 1,800 RPM to get 60 hz. Be certain your engine can deliver full power at 1,800 RPM!
2 - Alternatively you can use a cheaper 2 pole genny and run it at 3,600 RPM for 60 hz - but you'll need to belt drive it from the H engine to get 3,600 RPM.
3 - Unless you are not fussy about generator frequency the RPM droop (difference in RPM no load to full load) on the stock H engine governor may be troublesome.
Good luck - it sounds like a fun and worthwhile project!
Today's Featured Article - More Memories of a Field Service Engineer - by Brian Dye. Introduction: The author worked for one of the largest Ford tractor dealerships in England as a trouble-shooter on tractor engines, hydraulics and combine harvesters from 1963 to 1972. In 1972 he became a dealer manager and finally left the dealer net in 1975 to run his own electronic design and manufacturing company. [Editor] We live right in the middle of Norfolk. The dealership that I worked for sold Fordson Tractors from the 1920's and some of t
... [Read Article]
Latest Ad:
[More Ads]
