Re: ADDING A TURBO TO 656 DIESEL
Posted by ejr-IA on February 27, 2008 at 18:48:11 from (204.11.182.28):
In Reply to: ADDING A TURBO TO 656 DIESEL posted by skyharborcowboy on February 27, 2008 at 18:22:21:
I had a 656 diesel that I put a M&W turbo kit on.I gained 20 hp after I set the pump a little.If you go to high in HP you will crack the head and burn between the exhaust valves.Mine was a good running tractor had 5600hr when I traded for a 1086.
