Re: Used vegie oil in deisel farmall
Posted by gene bender on February 28, 2008 at 03:37:57 from (67.55.226.69):
In Reply to: Used vegie oil in deisel farmall posted by Farmerfred on February 27, 2008 at 18:25:08:
Sounds like a good way to screw up a good engine. By the time you get all the stuff needed to use that oil then cost of getting the used stufff a place to refine it store and so forth just buy the correct furl and save a lot of time and money.
