Posted by Bob M on February 28, 2008 at 09:19:23 from (151.190.254.108):
In Reply to: Re: H Generator posted by neblinc on February 28, 2008 at 07:15:11:
Commutator truing needs to be done on a lathe. However based on your photo the commutator on yours looks pretty good. I'd be inclined to undercut it like Jim suggests, then polish it up a bit and use it "as is".
A couple more things to check:
- Cracked/missing insulation on the interior wiring - especially the ungrounded brush holder leads. (Insulation here often tends to break apart when the end cover is removed and moved around.)
- The solder joints where the armature and field leads connect to their respective terminal posts.
Also as Jim suggests go real easy on the oil in the commutator end bushing. Excess oil and the commutator/brushes to NOT get along well together!
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
