Re: 450??????
Posted by Andrew Z on February 28, 2008 at 09:53:24 from (137.99.117.73):
In Reply to: 450?????? posted by Hoss357 on February 28, 2008 at 07:40:06:
I know there are alot of possiblities here to whats wrong, but i had that happen to my Super C a few years ago. I was looking all over the place to what was wrong carb, valves, etc.. and i thought hmm ill check timing at the distrubtor didnt really think that was it but sure enough there it was. Turns out the gear that drives the distrubtor had worn to the point that it skiped time. Just someting easy to check out before going deeper all you have to do is pull off the dist. cap and see if its pointing at the #1 pole when the marks on the crank pully are lined up. (make sure 1 is on the compression stroke though)
Just my though...
Good luck
Andrew
