Re: 450 LP Factory-Delete T/A Substitution Shaft
Posted by Owen Aaland on February 28, 2008 at 10:28:51 from (65.161.86.122):
In Reply to: 450 LP Factory-Delete T/A Substitution Shaft posted by Marty K on February 28, 2008 at 07:21:31:
The couple you are wondering about is where the seasonal disconnect would be located. Since your tractor has been converted to IPTO someone probably made up the coupler instead of adding the seasonal disconnect.
The hollow counter shaft in the transmission is used in tractors that have either a TA or IPTO or both. Since your suffice indicates that it came with a TA it will have the hollow counter shaft. The transmission driven PTO is driven by a different TA input shaft than the IPTO uses. Your tractor should have a single shaft engaged with the clutch disk and no hollow shaft engaging the clutch cover splines. Instead of just a plane shaft with splines on each end your clutch shaft also has a gear on it to drive the lower PTO shaft. This means the PTO will only run when the clutch is engaged.
If your tractor had neither a TA nor an IPTO then the transmission counter shaft would be solid like an M with a PTO like an M.
Today's Featured Article - Trailering Your Tractor - by Curtis Von Fange. One of the fun things of summer and fall are the parades and tractor shows that go on across America. Many owners of tractors travel long distances to attend these shows and they usually take their restored iron along with them. Safe trailering practices and inspections will ensure that the event is a fun one. A good habit to develop when using a trailer is to give that ‘quick look over’ before taking it on a trip. Before hooking up to it check the tongue for proper operation. The latche ... [Read Article]
