Posted by bc on February 28, 2008 at 11:25:58 from (75.27.227.202):
Hi, I've got the 2606 brakes that had the adjusting ball tightened all the way up and they still didn't bite. Then I backed the ball off and stuck in about an inch worth of washers to get brakes. I took one side apart a posted a while back about it.
The old disks did not appear to be very worn. They were 7/16" thick and still had about 1/16" grooves on each side of both discs. The metal plate surfaces looked good with just some minor rust that I can sand off. The plates expand ok and the ball bearings inside look ok. The springs hold the plates tight together.
I inquired of the thickness of new brake discs and they are only a 1/2" thick which isn't enough difference to take up all the adjustment. My question is why did the brake adjusting ball loose all of its adjustment and need a spacer to work? The adjusting rod will only pull so far.
The only other thing I just thought of, but won't know till I look, is that the brake pedals on the shaft is missing a woodruff key or something but I believe only the left brake uses the shaft but the right brake has the same problem and the right brake is a direct pull on the adjusting rod so that can't be it.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
