Thats correct the front gears would of had to been changed as a set. They must have done that or there wouldn't be much point in putting the IPTO on the rear. Evidently the center housing was removed sometime and it would have been easy to put the pto shaft for IPTO through the transmission counter shaft then. But they must have left the other shaft in is the reason for the coupling being made up. The non live pto used the same size splines on the rear of shaft through counter shaft as what a M tractor has on the end of the pto shift sleeve, which looks like the end welded to coupling in his picture. Not sure if I understand what your saying about the pto drive speeds. The input shaft speed or speed of the shaft driving the IPTO is faster than non live pto. If he was driving the IPTO from not live gears the output of IPTO would be slower.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
