Re: Farmall M engine update
Posted by ChadS on February 28, 2008 at 19:17:31 from (4.224.78.167):
In Reply to: Farmall M engine update posted by 1 Dollar on February 28, 2008 at 13:06:03:
Ive seen worse,,, where that is,,,, Id put about an inch of hard block in the water jackets,,, enough to put about a half inch over the highest pit,,,, wont be no water there to leak thru... wont be enough water missing to affect much,,,,, if your running dry sleeves,, say like a stock M sleeve,,, thats what Id do and not think about it ever again. Another option would be to maybe JB weld the pits shut,,,, smooth it out really well and then slip the sleeve in,, maybe add a dab of sleeve adhesive to help??? Id do the hard block trick,,,, if no boring is being done,,,, and sleeves are used,,, make sure the water jackets are super clean, maybe hottank or lightly sand blast the area before the filler is done,,,,,, to get the rust out of the bottom. Ive seen worse,,, and I wouldnt be afraid of it. JMHO,, ChadS ChadS3@hotmail.com
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
