Posted by Janicholson on February 29, 2008 at 08:56:59 from (199.17.6.122):
In Reply to: M CARBURATOR posted by JOHN WOODARD on February 29, 2008 at 08:24:11:
Simple and effective packing (if the needle is smooth) is Teflon tape twisted into a rope and wound around the shaft. Approximately the same amount of material is needed to make sure the packing is not too small allowing the packing nut to screw in all the way to thread bind. If too much is put in, the packing nut will not find threads to start on the needle base. Do not over tighten when assembling, the Teflon can be squeezed out the packing nut gap. This method takes less tension than the stock packing rope. Thin packing rope/twine is available at good plumbing supply houses as well. JimN
Today's Featured Article - New Hitches For Your Old Tractor - by Chris Pratt. For this article, we are going to make the irrational and unlikely assumption that you purchased an older tractor that is in tip top shape and needs no immediate repairs other than an oil change and a good bath. To the newcomer planning to restore the machine, this means you have everything you need for the moment (something to sit in the shop and just look at for awhile while you read the books). To the newcomer that wants to get out and use the machine for field work, you may have already hit a major roadblock. That is the dreaded "proprietary hitch". With the exception of the
... [Read Article]
Latest Ad:
[More Ads]
