Re: bent shaft
Posted by tn terry t on February 29, 2008 at 19:41:24 from (205.188.116.144):
In Reply to: bent shaft posted by steelfronts on February 29, 2008 at 17:25:21:
Red Mist said: (quoted from post at 15:16:12 03/01/08) TNT: I have straightend shafts like that (not IH distributor shafts, but similar). It usually takes two or three tries to get it right - with a hammer and a true flat surface. Advice: Don't shoot for absolute perfection; it won't happen, but if you are persistant, you will get within an acceptable range. Good luck.
mike
i guess i should have looked before i leaped in here. i just came back from the shop and i did what you said and it workied! fireing on all four now. maybe next time i will go ahead and try things before i bother you guys thanks you sir
