I know what you mean about using the tractors. 90% of my problems come from having things sitting around. If I used them weekly even I wouldn't have half the trouble that I do.
When I first got the Super C the hydraulics worked fine and then after using it a while they started to leak down if you left a load on them (or more annoying the fast hitch drawbar would drop). Then after I discovered the state that the timing gears were in I decided it was time and the touch control would have to come apart. The o-rings are all pretty well perished and on the check valves there are small springs at each end. One of these was broken, jamming up the check valve. Also with no filter on the system it can't do any harm to clean it out occasionally. tractorsam
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
