Re: M/SM/400/450 cam question
Posted by Charles E. McNelly on March 02, 2008 at 08:44:31 from (72.18.77.252):
In Reply to: Re: M/SM/400/450 cam question posted by D Slater on March 01, 2008 at 18:36:30:
Hi Dave, What made me wonder was the fact that both the M manual and 450 manual showed the lift the same and the duration of the valves the same.
I thought there would be a differance in valve timing on the intake side from what all has said.
Thanks,
Charles
