Re: H engine parts
Posted by Steven f/AZ on March 02, 2008 at 15:35:57 from (24.121.155.84):
In Reply to: H engine parts posted by Ricky A Beebe on March 02, 2008 at 15:30:52:
There is a serial number stamped into the block below the #1 spark plug. Any decent parts place should be able to get the right parts based on serial number and casting numbers of the block and head...
"Appears" fine is not good enough for crankshaft specs, you need to have the journals checked with a micrometer... or you can use plasti-gauge when assembling to be sure the clearance is right.
