Re: International 240 3 point stuck
Posted by GA Dave on March 02, 2008 at 17:59:35 from (209.86.226.15):
In Reply to: International 240 3 point stuck posted by Jake Winn on March 02, 2008 at 12:29:57:
The hydraulic fluid is separate from the rear end/transmission. Fill plug is under the gas tank behind the clutch housing. About 1-1/8" plug. I think this is the big plug in question 3. Drain plug is under that plug (one of three big plugs). Could be ice if it's been that cold there. Not sure about the two small plugs. David.
