Posted by JimB2 on March 02, 2008 at 18:45:55 from (99.241.179.24):
In Reply to: IH 784 problems posted by BradA on March 02, 2008 at 16:35:40:
Hi Brad, the hydraulic brakes are the weakest point in the 84 series tractors. The the hydraulic brake circuit is fed by the return hydraulic oil from the oil cooler and dead ends in the brake pistons by rear axles. Problems can be caused by leaking "O" rings on the brake cylinders, cracks in the brake lines or air bubbles in the hydraulic oil. Make sure to use only IH Hytran or equivalent hydraulic oil and you can over fill the transmission with 5 gals of Hytran to be sure when using a loader or remotes not to suck air into the hydraulics. You can check for leaky "O" rings or cracked hydraulic lines by bleeding the brakes and then let the tractor sit for a day or two and before starting it, depress each brake pedal one at a time, if one or both go to the bottom then there is either a leaky line or "O" ring.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
