GEAR OIL
Posted by JOHN WOODARD on March 04, 2008 at 16:20:08 from (64.234.11.92):
I HAVE A RUNNING M TRACTOR WITH GAS ENGINE BUT AM GOING TO SLOWLY REBUILD. I WANT TO DRAIN AND REFILL FINAL DRIVE AND TRANSMISSION BUT AM NOT SURE OF TYPE OF OIL. MY MANUAL SHOWS CAPACITY BUT NOT WEIGHT.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
