Re: ok guys its carburator time
Posted by bc on March 05, 2008 at 07:26:30 from (69.149.215.200):
In Reply to: ok guys its carburator time posted by tn terry t on March 04, 2008 at 22:39:33:
I don't know for sure. The IH carbs have a little round tag with the number pinned to the top side of the throttle throat body.
You can call and ask the guys at this yt website on what they recommend. You need to serial number of your tractor. The cutoff is above or below # 65000.
If you want to get a kit, then you just as well invest the $20 for a gallon size carb cleaner dip tank at your local auto parts store and start cleaning it to find a number. Then blow out all the passages with an air compressor.
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
