Re: Electrolysis tank - how long does it take?
Posted by tesmith66 on March 05, 2008 at 10:20:26 from (130.76.96.14):
In Reply to: Electrolysis tank - how long does it take? posted by Re: 460 is a knocking... on March 05, 2008 at 07:07:31:
NawlensGator said: (quoted from post at 09:42:12 03/05/08)
If you add more surface area the amps should/will go up.
Check your amps and see if you are aready maxed.
I use a 15 amp charger and when I added some Borax the amps went up from 7 to 12. I think the borax increased the ion density, but then I'm not a PhD chemist (thank goodness).
Thanks for the tip. Could adding more soda do the same thing?
