Serial on right side = 300 farmall or utility, maybe farmall 460. Serial # to high for 350. If steering shaft goes to front of tractor above engine thats probably a farmall 300. If the steering shaft is going directly into steering gearbox with linkage rods on both sides going to a wide that could be a 300 utility. If steering shaft goes by left side of engine that could be a Farmall 460
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
