Re: oil?
Posted by RustyFarmall on March 06, 2008 at 05:45:52 from (209.152.78.71):
In Reply to: oil? posted by Mark W. on March 06, 2008 at 05:29:01:
You use the same oil in the air cleaner cup as what you use in the engine, and that cup should be thoroughly cleaned and fresh oil put in every time you change the engine oil. If the air cleaner has not been serviced in awhile, you will probably need to use a putty knife to dig out the muck.
