Re: Lube on O-ring sleave seal?
Posted by El Toro on March 06, 2008 at 08:38:50 from (205.188.116.73):
In Reply to: Lube on O-ring sleave seal? posted by Brian J on March 06, 2008 at 08:34:04:
Use dish dertergent the brand makes no difference. Make sure that block area is clean where the new seals are installed. Do the recessed area in the top of the block where sleeves sit. Hal
