Re: Lube on O-ring sleave seal?
Posted by cmccoy7 on March 06, 2008 at 12:20:00 from (206.138.130.3):
In Reply to: Lube on O-ring sleave seal? posted by Brian J on March 06, 2008 at 08:34:04:
No brake fluid! This is very very bad on rubber seals. Use dish detergent like others have said. It works well. Chris
