Re: H questions and introduction
Posted by GordoSD on March 06, 2008 at 19:39:43 from (66.115.200.140):
In Reply to: H questions and introduction posted by Flathead Youngin' on March 06, 2008 at 18:23:24:
I don't know if you are a conservationist, or a hunter, but you have the ideal acreage for some deer and quail hunting. IF you plant some nice food plots. Forget mowing it down, a bushog is wildlife's worst enemy.
This would allow you to have a lot of fun working your H. With the three point you can mount a disc, a broadcast seeder, use for fertilizer also, a sprayer for burning down fields prior to palnting. And a sickle mower for edging. An drill or palnter for row crop or grains.
Call your local wildlife and conservation groups on how to get started, then get the equipment you need.
And there's some $ in hunts, whether it's archers or muzzleloaders. 40 acres with woods will hold deer there that will never leave if you have food and water for them.
Google up QWTM , Quality whitetail management for a start.
Good Luck
Gordo
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in ... [Read Article]
