Re: Lube on O-ring sleave seal?
Posted by Owen Aaland on March 07, 2008 at 05:08:30 from (65.161.86.17):
In Reply to: Lube on O-ring sleave seal? posted by Brian J on March 06, 2008 at 08:34:04:
I use a silicone lube specified for use in assembly of Eaton Road Ranger truck transmissions. It is extremely slippery and will not dry out like soap.
The o-rings used to seal your sleeves will not be damaged by using oil. If they were not able to withstand exposure to oil they would fail in use because they have to seal oil from the bottom and coolant from the top.
